STM32 control board - FLYHERO
Hello everyone!
I am trying to develop a custom control board together with its software. The project is still in a very early phase of development but I hope to make it fully functional. Source code is hosted on https://github.com/michprev/flyhero.
The control board is currently quite large and consists of voltage regulation circuit (I don't use BEC ESC right now), LEDs and headers for other components: NUCLEO-F446RE board, MPU6050/9150/6500/9250 IMU, MS5611 barometer, ESP8266 WiFi module and of course ESC wires headers.
The board does not have radio receiver.
3691347600?profile=originalProgram for the Nucleo board is made of modules (each folder on Github is one independent module) and the main The_Eye project which links other modules.
There are 2 main versions of the program. On 'master' branch I use DMP sensor fusion which is performed in IMU and sampled out at 200 Hz. The second version is in 'non-DMP' branch and performs raw data readings from IMU at 1 kHz and fuses them using complementary filter.
In both versions I am running not synced 2 kHz PWM (125 us minimum, 250 us maximum, 500 us period) just because it is compatible with Oneshot125. I would like to implement Oneshot125 as soon as possible.
The quadcopter is controlled from a mobile phone where is possible to set PID constants even during the flight. Unfortunately I wasn't able to comfortably take off yet.
I am using Quanum Neon 250 frame, 20 A ESC with BlHeli and Multistar Elite 2306-2150KV 'MINI MONSTER' motors.
3691347801?profile=originalI am attaching data log from non-DMP version with no props and motors running at max 20 % speed. It looks like IMU suffers vibrations.
3691347891?profile=original
Is it that critical to make it not able to fly? I have tried many PID constants variantions with no success. Do you have any other suggestions how to make it fly? I can supply any other data logs or even videos with 'take offs'.
Thank you!
EDIT: Realised that I was mixing rads with degrees, fixed reuploaded correct image and attached file. 20 degrees error looks really terrible. Any suggestions for software to correct this? Should I use another frame?
log-20-6-2017_14-11-56.xlsx
