Strange Behavior in Mapping Mission (alt changes)
I just put together a (gorgeous) Alien 560 quad last night with a Pixhawk.
This morning I decided to fly a mapping mission, and the quad performed very well, but there were a few hiccups in the mission.
Even though the entire mission was at 50m, at several points in the flight, the quad ascended straight up more to 80m and then descended again and resumed the mission. Also, at the end of the mission, upon RTL the quad ascended up to 100m and then seemed to just stop there. Luckily it was close by, so I just took control and landed it.
Here is the mission I programmed:
3691218234?profile=original 3691218380?profile=originalAnd here is the path that the quad actually took. You can clearly see the spikes. They seem to happen at waypoints 5 and 13, and upon RTL at the end of the mission.
3691218409?profile=original
3691218343?profile=original
Here is a graph of the altitude and the PWM value of channel 5 (controls flight mode). You can see that the spikes happened without any input from me. With the 3rd rise, I switched into RTL. You see the quad descend slightly, and then return back to the initial altitude. Then I switched to stabilize and landed it.
3691218455?profile=original
Any ideas on what might be going on here? I don't really care so much about the issues during the mission itself, but the failure to RTL (after the mission AND when I switched to RTL) was very concerning.
Thanks in advance!
2015-06-22 08-54-15.tlog
2015-06-22 08-54-15.tlog.kmz
  • And here is the aircraft itself:
    3702034812?profile=original
    3702034837?profile=originalSpecs:
    18-20 minute flight time
    Motor: SUNNYSKY X4108S 690KV
    ESC: Afro 30A OPTO
    Prop: 12x4.5 Gemfan
    Battery: Zippy 5800mAh 4s 25C
    Airframe: Alien 560 Folding Kit
    Flight Controller: 3DR Pixhawk
  • I've attached the telemetry log and KMZ if that helps.
