Stream rate limits
Due to some regulatory issues I am trying to reduce some telemetry stream data rates using the SR3_* parameters. I would even like to disable some steams completely. Unfortunately, there must be some hard-coded minimum limit per parameter in the ArduPlane firmware (4 per second in most cases).
After some hours of grepping around in the sources, I am still did not find the right location. Any hints?
  • Normally, I am using MavProxy instead of MP, but may be it has interferred and silently reconfigured my APM when it was connected once...
    Thanks,
      Holger
  • Hi,
    I think your are not finding them because they are not there :)
    The ground station request streams with whatever rates. So you have to look at your ground station config. In APM Mission Planner, it's in Configuration->Planner, item Telemetry Rates.
    Regards
    Soren
