Supported XBee Radios
Is there a list of supported xbee radios?I have 2 XBee XB24-B's and I'm getting the error: Connect Failed Details -> "Timeout on read - getParamList 32 Packets were received, but no parameter packets were received". Works fine over USB. The test program correctly prints port 0 on USB and port 3 on XBee. Running APM1 - 2.8.1 Quad, Mission Planner 1.2.25
  • Admin
    @Rob,
    I believe that the XB-24Bs are really designed for a Zigbee mesh network and may not work well in this application. You might be better off using the Xbee Series 1 (2.4GHz) or the Xbee Pros (900MHz) in the peer to peer mode.
    Just a thought.
    TCIII
