SweepWings FPV/AG/3D mapping wings
Hi Guys,
I was told to check this place out for UAV stuff. I have been working on flying wings for over 2 years now and started to make my Juggernaut "Pathfinder" airframes. I wanted to make a cheaper frame that everyone could afford to start out. My goal was to keep the cost down and provide a solid frame to withstand the tough landscapes. This is all just working with what I have already in my shop. I would love to find a smaller camera and Flight controller to save room.
All hand cut by myself and out of EPP.
thanks,
Ruben
test 1 prototype  48" juggernaut
https://www.youtube.com/watch?v=RDjB_iWeuZk&list=UUNbMgLsoigN6DCw8O-wmSng
test 2 prototype  52" Jugg Pathfinder
https://www.youtube.com/watch?v=drzYAaQfe2Y&list=UUNbMgLsoigN6DCw8O-wmSng
https://www.youtube.com/watch?v=1o_19_iOxp0&list=UUNbMgLsoigN6DCw8O-wmSng
Behemoth 60" (can be made for mapping large areas)
https://www.youtube.com/watch?v=28T6UHK2lso
Dreadnought 81.5" (fit everything inside)
https://www.youtube.com/watch?v=HiK58N6NmHg
Payload testing
https://www.youtube.com/watch?v=dWy4MMAAIoM&index=7&list=UUNbMgLsoigN6DCw8O-wmSng
    You need to disable the eleven mixing in the Tx and enable output mixing in the pixhawk
  • Ruben hello, I have a Juggernaut and have never been able to fly it, not sure what happens, is with 3dr Pixhawk, GPS, telemetry and engine Turnigy 3536 1050kv. My radio control is a Turnigy 9x, when in manual mode the elevons work perfect but when I switch to any other mode, such as automatic, misconfigured and begin, begin to function as if it were a plane with tail.
    I've tried almost everything, but does not work me.
    you kindly help me ?? what can I do?
    I thank you from now.
    Mario Rojas.
  • What is the longed flight time you have achieved w/ ur flying wings? Using li-ions?
  • How are you managing to cut the EPP?
    • Hi Marc,
      I use a hot wire and sand them all by hand. No cnc at yet.
      • Hi Ruben thanks for the Info, How many amps are you using on the hotwire? I have never cut EPP before but i hear its much tougher to cut that regular high density foam.
