Switching between two motor pairs
I what order am I suppose to turn everything on?
Power to Mega, ESC, transmittor?
Some times it does not want to compensate when I tilt the quad. (when holding it in my hand) Then I reboot and try another startup routine, sometimes it works.
And when I turn the throttle on a little bit it runs 1 pair of motors for 2 sec and then the other two motors for another 2 sec and back again to the first pair. Normal?
In arducopter configurator v1.1 I get an error when I try to update the PID values. It says "update unsuccessful! try again?" It doesn't say anything when I initialize the EEPROM, well it doesn't give me any errors.
Thanks for your hard work.
Kristofer
  • first u should power on the transmitter
    then ur quad, not the other way
    it should work
