Tarot Gimbal Initialize Tip
Hi everybody,
Just wanted to share a tip with everybody that we discovered this weekend.
The Tarot Gimbal will not initialize while moving. This may not sound like an issue, but if you are launching off a moving platform such a boat (what we were doing), it is something to consider. You can test this out by powering on your vehicle while walking around. We observed that while doing this (and when on the boat) that the yellow LED on the tarot board would stay lit, and it wouldn't initialize. As soon as you put it down and let it sit for a couple seconds, it starts up.
If you're on a boat, bring anchors!
cheers
-Patrick
  • Is there any trick on work around for this?  I was in some rough seas the other day and had to go to shore in order to initialize and take off?
