  • Hi Mike, as Chris pointed out, you need to have the GoPro camera attached on the gimbal for it to work. The brushless motors do not have enough power to hold the position of the gimbal if it is not balanced. And the T-2D is designed to be perfectly balanced only when the go pro is attached.
    I can't really tell from that video, but it will only work with a GoPro attached (for weight balance).
    • Spot on.  Thank you Mr. Anderson.
