Testing the AMP and Sheild
I just finished soldering all the connections for my APM and Sheild.  I had a bit of trouble with two pins and had to do a little custom work to complete the solder job.
Is there a good way to test and make sure everything is working correctly before I continue building?
Thanks!
  • Yes it appears I am that dense lol.
    I reloaded the board with the ArduCopter code and it connects at the correct baud rate. My applogies!
    I think its time for bed...
    As for the manual, I was a bit lost when it came to installing Arduino and what code to load and all of that.
    I will look over the process tomorrow and see if i can't come up with something a little more clear for the new people like me.
  • Thank you, I will give this a try!
    Yes, load code and run the tests in the manual. There are loads of them.
