The Tekken Quadrotor
Hello everybody,It is finally the time to build the Quadcopter for meeeeeeeeeeeeeeeeeeeeFirst, I draw the diagram on SolidWorks, and now I'm selecting the parts.The approximate gross weight of my quad will be around 5 kg with HD cam.I will select four Emax BL2826 (40 2-stroke) High Torque Brushless Outrunner, with thier ESC and propellers. nothing specific. I will jump to the Hobby shop and see what fits!I also think it must have four batteries, one for each motor.I also will be any 6-CH Futaba receiver, to match with my transmitter.I will build the board from scratch!for sensors I will use MTi-OEM from http://www.xsens.com/en/general/mtiwhat else.... ?Please if I am doing anything wrong, I would like to hear your suggestions.If there are any helpful suggestions I would be glad to hear it too.
  • To lose some weight of my quad, I think I am gonna buy "gopro camcorder"
    I looked up the official website, and decided to go with "HD HERO Naked" because of good price, lightweight, and clear videos.
    I also will check for other useful accessories.
    Any suggestions ?
  • Thank you Daniel G.
    We are going to use 4 batteries, each one 4S 2400mAh. Is that enough ?
    If not, I will buy 4 batteries 4S 5000-10000mAh like you advised.
    About the props, I am going to buy 13x8, you think they're enough?
    The design of my quad is attached. would you mind take a look.
    The 5 KGs is a lot. you are right. there are two reasons.
    a- I am using aluminum not Fiber, cuz I have no experience in it.
    b- I am planing of using professional camera Full HD with full axis control , which will add high weight on the quad.
    c- later, I am thinking of installing a parachute restoring system with trigger, so in case of engine failure I won't lose my beloved quad :)
    Thanks for your kind advise, and hope to hear from you.
  • Parts list
    I would like to share with you my parts list.
    Please if you can advise better solutions , I will be thankful to hear it
    No. Name: Specifications x Amount
    1. Brushless motor: EMAX BL2826 (.40 2-strok/.60 4-stroke) High Torque Brushless Outrunner. KV-950, Batt 3/4 cell -2400mAH, shaft-5mm Prop 13x8, ESC-60a x 5 pcs
    2. Batteries for brushless motor: 4 Cells 2400 mAH x 6 pcs
    3. Batteries Charger: For above batteries x 1 pcs
    4. Propeller : 11x7 or 13x8 (bigger is better) Plastic rotation direction: CW x 4 pcs
    5. Propeller : 11x7 or 13x8 (bigger is better) Plastic rotation direction: CCW x 4 pcs
    Note Propellers CW and CCW must produce identical trust
    6. ESC: Electronic Speed Controller ESC-60a (or suitable for motors) x 6 pcs (or 8 pcs according to price)
    7. RC Receiver: Receiver FUTABA 6 Channels x 1 pcs
    8. Receiver Battery: Receiver Battery x 1 pcs
    9. Receiver Battery Charger: For above battery x 1 pcs
    10. RC Crystals: RC Crystals Set (R & T) x 2 pcs
    11. Accelerometer: Accelerometer adxl330 x 3 pcs
