The problem than I may have, is the lost communication between the plane and my computer, because  this works perfectly on the ground but in flight, communication is completely lost, could it be foreign interference or any condition?
A monopolo antenna is most efficient that a dipolo antenna or viceversa?
  • Are you using 3DR radios for telemetry?
    Are you using some video for FPV on 900MHz?
    What was the approx range when you lost your communication?
    What was your position of antennas on both plane and ground? Both vertical, one tilt, both tilt?
