So here's the issue...(with the APM2 running the arduplane software)
The throttle is reversing in a strange way. When in manual mode, everything works as expected, but when the APM2 is switched into stabilize, auto, etc... the throttle is reversed.
I tried switching the throttle reverse parameter, which did the trick for the APM controlled modes, but it also reverses the throttle under manual mode.
I've re-calibrated, and tried everything we can think of on both the APM2 and our transmitter (DX8) but to no avail.
Anyone know how I might fix this problem?
Edit: Possible solution found...i'll update.
