Thrust Control
Hi. I am using APM 2.0 for arduplane. During autopilot function, the thrust was sometimes increased and sometimes decreased by APM. Actually I could not understand why and how the APM increases (or decreases) the thrust. Is there any nominal airspeed coded in APM? I am also looking for a way to control this thrust control function with ground testing. I will be glad if someone helps me. Note: I am using airspeed sensor.
Best regards,
zafer
    If you are using the airspeed sensor, then the throttle is used for altiude control.  Techinically, it is used for total energy control, but you can think of it as altitude control.  Nominal airspeed is set as a parameter.
