hi,
i have seen several posts regarding people wanting to measure the thrust of their quad/hex some using what look like digital kitchen scales, however iv seen none mention the use of a set of fishermans scales, i would have thought these would have been perfect as they would be measuring the lifting force directly and the fact there designed to measure weight in exceess of 30/40lbs.
the only problem i can invisage is sufficiently ancorin scales to ground.
appologies if im misteaken.
Kind of an old post but this item is fairly new.
Turnigy Thrust Stand
