Goodnight. Can someone assist me with tuning my 450 size heli. I have so much collective pitch. About 40 deg positive and and about 22 deg negative. I am looking for the 10% positive and negative. Where does one set this?
If you have so much collective, I guess you should change the position of your ball link. With only 10% of the range of the servo you may suffer from the resolution problem.
Chadel,
In the Heli Setup page you should see a "Swash Travel" section in the middle. If you set the Top and Bottom values you should be able to reduce the amount of movement. Alternatively push the "Manual button" and only move the transmitter's throttle stick over a smaller range.
Perfect. Thank you so much. Solved.
