Tracking - negative tilt
Hi,I would like to setup an ardustation for tracking, and the manual explains how to set the tilt limits to 0 to 90 deg. Is it possible to set a negative tilt, so that the antenna points down if I fly lower than where the station is (down a cliff)?Thanks!
  • Got it. Thanks.
  • The only way to do this would be to expand the range of the tilt servo to more than 90 degrees and to calibrate it. This requires modifying a number of hard coded constants in the Ardustation code.
    I've stopped working on the Ardustation code, but it is technically possible.
    Heino
