RT @gclue_akira: レースまであと3日。今回のコースは激ムズかも。あと一歩
#jetracer https://t.co/GKcEjImQ3t
RT @chr1sa: The next @DIYRobocars autonomous car race at @circuitlaunch will be on Sat, Dec 10.
Thrills, spills and a Brazilian BBQ. Fun…
RT @araffin2: 🏎️
After hours of video editing, I'm happy to share a best of my Twitch videos on learning to race with RL.
Each part is…
Sorry but important things first. While in your head, it may seem logical to power everything from the main battery, Don't do this! Even a good engineer who fully understands all of the electrical problems would see that the risk involved from any fault will likely result in a crash. In other words, people have enough problems just adding a current sensor and messing up the magnetometer and other issues, let alone EMI RFI noise, interference, and possibly control problems. Keep your flight system separate from your other gadgets as much as possible, to include power source. This is the single biggest mistake most people make as they introduce ground loops and other fault paths by combining the systems. No tradeofff is worth a crash where everything is destroyed or even worse, lost in a flyaway.
Not trying to knock the idea down, just give you some solid proven guidance on implementation. If something happens with the camera and cell or WiFi, no big deal, you still land safely, but if tied together, likely the cause of the crash and the destruction of even more expensive gear.
If you're going the DIY arduino route, Adafruit's TTL Serial Camera is probably your best bet. They have a great library and tutorial for this: http://learn.adafruit.com/ttl-serial-camera/overview
It shouldn't be too difficult to pair it with say an Arduino Pro Mini that is programmed to respond to an APM's camera shutter PWM signal. On receiving a shutter command, the Pro Mini could trigger the TTL camera to take a 640x480 JPEG and transfer it to the Arduino. The Arduino could then store it onto an SD card. If you're also using a Wifi shield, I think you could have the Arduino then POST the pics from the SD card to a receiving script on your webserver, though you're either gonna have to know what you're doing for how to write that or find a library/tutorial that breaks that down. Check: http://arduino.cc/en/Tutorial/WiFiWebServer
Probably not the level of automation your looking for but Sony's wifi remote app can snap pictures using their latest NEX-5R and NEX-6 cameras. A 2MP copy is sent back to the control device (iOS/Android/PC). I think the GoPro's app is able to do something similar. This is of course call manual.
I think best way would be with 3g or 4g but Wifi might be easier if u don't plan on going far
I'm starting on a project to do something similar. Although not far advanced yet, my intention is to put an android device with a cellular connection on my plane. The onboard app will contact a server as connection allows for commands and then upload the photos.
