i have done the transmitter calibration with the configurator,
all seems ok and it gets the right values and positions,
i hit save,
but then when i disconnect and reconnect the copter to USB, the "transmitter" screen in the configurator screen shows all values round ( 1000 to 2000) instead the calibrated max and min.
in flight, when i arm the motors no one start to spin,
i add some throttle and some begin, and i have to add some more throttle to get the others spin.
takeoff and flight is perfect.
yes i've also done esc calibrations through CLI.
the problem started as i've re-loaded the ardupirates NG code yesterday with the camera stabilization turned on, so i had to re configure all.
thanks for help!
Motors not spinning when arming is caused by low-throttle point set too low (<1000, typically). It happens sometimes. To solve it, run the low throttle calibration in CLI.
Re: magneto and offsets...
Two stupid questions:
1) does your Windows locale use decimal point or decimal comma?
2) you did click Update after setting the magneto on in Configurator, right?
