Sorry for the repeated question. How to involve servos and power on my Trex ?
My problem is: What - Where, so I did not spoil it. . .
My things: DX7 with 6 Channel receiver, ESC with BEC - Kontronik JAZZ 55 LV, 3DR Reciever & Transsmiter
Could anyone reasonably draw a wiring diagram to understand it also so idiot like me? :) Such as here: http://code.google.com/p/arducopter/wiki/TradHeli_ConnectingAPM or something like Steb-by-Steb Guide for Jerks
My current involvement by previously identified information .... 3 servos are moving .... the main rotor does not work. The rear rotor is moving a little to about 10% ....
Receiver out to APM2:
Aileron -> APM Ch.1
Elevator -> APM Ch.2
AUX1 (Pitch) -> APM Ch.3
Rudder -> APM Ch.4
Gear (Gyro) -> APM Ch.5 for flight mode switching.
Throttle -> Directly connect to the ESC
APM2 to Servos
Ch1 -> Front Left Servo
Ch2 -> Front Right Servo
Ch3 -> Rear Servo
Ch4 -> Rudder
PLS HELP :/
Sorry for my bad English. I wrote it also more beautiful, but .... GOOGLE TRANSLATOR
(I hope someone will understand :)
Something's wrong ...
Inputs from 6 CHANNEL SPEKTRUM RECEIVER TO APM 2.0
1. Aile
2. Elev
3. Throttle
4. Rudd
5. AUX1
OUTPUTS on APM 2.0
1. Front Left Servo
2. Back Left Servo
3. From ESC KONTRONIK JAZZ 55-LV
4. Rudder Servo
5. Front Right Servo
DX7 / Mode 1
Front Right servo - no movement
Throttle - works
Roll - does not work
yaw - servo moves at least (though in the settings - HELI SETUP I allow manual setting --- works normally ....)
Pitch - bottom position starts the engine: D
I'm sorry, I can't really help because Spektrum radios are really weird. They output functions on strange channels, and the manual actually doesn't tell you what is what. It's almost like they don't want you to fly a helicopter with them.
It sounds to me like the only issue you have is the throttle is not working?
