RT @gclue_akira: レースまであと3日。今回のコースは激ムズかも。あと一歩
#jetracer https://t.co/GKcEjImQ3t
RT @chr1sa: The next @DIYRobocars autonomous car race at @circuitlaunch will be on Sat, Dec 10.
Thrills, spills and a Brazilian BBQ. Fun…
RT @araffin2: 🏎️
After hours of video editing, I'm happy to share a best of my Twitch videos on learning to race with RL.
Each part is…
Hey guys,
I'm a newbie as well, and am in the process of building a y6. Can anyone tell me whether my present configuration will work or if I would have to make changes. In that case, any suggestions? Any and all help will be appreciated.
Hobbyking multi rotor control board v3.0
Hobbyking 2.4GHz 4ch mode 2 radio system
Fc 28-22 brush less outrunner 1200kv
Turnigy 12v 2-3s basic balance charger
Turnigy multi star 20amp multirotor brush less ESC 2-4s (opto)
9x5 carbon fiber props
Is there anything else I would need to make this beast take off?
Thanks!
Mate, the easiest thing is to get a cheap voltmeter and see whats coming out of your power module. This will save you a lot of time - you never know, it might be the power regulator on the APM board - but until you've done what I suggest you're shooting in the dark.
This is my tricopter configuration and it flies great with APM, and it's aerobatic too:
rcexplorer style frame with 36cm 10mm hard wood booms (too flexible actually, 12mm or carbon is better)
Uncased APM 2.5 with Arcucopter 3.1 firmware
MinimOSD
HQ 9x3.8 or Graupner 9x5 props
T-Motor MT 2216 900kv motors tied to booms with double sided tape and 2 zip-ties on each side.
RCTimer 20A ESCs with SimonK
3000mah 4S 35C Turnigy Nanotech battery
Hobbyking landing skid set for SK450
Crius LEA-6M GPS
I had to tune down the stabilize P gain though to stop the tail (with the top heavy rcexplorer style yaw mechanism) from wagging.
Video with some rolls and flips:
https://www.youtube.com/watch?v=Ood_cvlKgeY
Other FPV videos:
https://www.youtube.com/watch?v=XhuZppW60Ns
https://www.youtube.com/watch?v=eAHUeLgGwEE
Good build advice at rcexplorer: http://rcexplorer.se/projects/2011/09/the-tricopter-v2-5/
Excellent APM config + tips here: http://www.rcgroups.com/forums/showthread.php?t=1792924
After playing with kk2 i'd like to go for the apm 2.5. I'm tired of messing with the PI settings. Is apm easyer to set and fly? What sensors do you recommend for a more steady flight, taking off and landing? if i need any at all
Is there any Super Simple Gimbal equivalent for apm? What is it called?
Do i need to place the tricopter on a level surface for takeoff, like with the kk2? I find this hard to do most of the time.
What are the downsides of apm in your oppinion?
Thank you!
i've flown my apm 2.5 tricopter for a while, i've tried stab, alt hold, loiter, auto, circle, and rtl..
my setup is:
apm 2.5 with mediatek gps
rctimer 433mhz radio
DT700 + 11x4.7 props
HK F30A esc + simonK fw
hxt 5010 servo
4000mah zippy compact 3s battery
6ch hk6s transmitter and receiver
I have a question. I'm setting up my APM 2.5 board (fw 2..9.1) on a tricopter. I've installed a digital servo for the yaw tilt platform. It seems a little 'steppy' with stick input. I'm thinking this is because of a 50hz servo refresh rate. While I've found how to reverse the servo direction in MP, I've been unable to find if the yaw server refresh rate can be changed/adjusted. Is this possible or is it hard coded (and if so) to what value?
Thanks in advance...
Motor: ROXXY BL OUTRUNNER 2834/08
ESC: ROXXY BL CONTROL 930-6
Servo: HK15158A Digital BB/Coreless Mini Servo 25g / 2.8kg / 0.07s
I just finished building my first tri-copter two weeks ago, and have about 20 flights on it.
Quick run down of equipment and parts
APM 2.0 with external GPS – To be upgraded with APM 2.5 and better GPS
Radio: Futaba 9C with FrSky D8 Module
Receiver: FrSky DH8 – 8 channel
Airframe – Hobbyking Turnigy Talon Tricopter V1.0 Carbon Frame
ESC – Hobbyking Turnigy Plush 18 amp
Motors – Turnigy Airdrive 1020kv
Tail Servo – Generic Corona (I stripped the servo the other day catching the tri when I knocked it off the bench.) I have a Turnigy 396 on the way as a replacement.
Propellers – I currently using 10x4.5, I also have 11x4.7 and 9x4.7 that I will be trying out.
Batteries: Various 3 cell lipos – Mostly Zippy 2200mAh 20C
Roll and Pitch Camera Mount – Goodluckbuy Scopion Something or another. Hobbyking has it too
I sound like an advertisement for Hobbyking...
Total build time: 6 hours
Comments: Used stock Ardu Tricopter setup. I had to reverse the “tail” servo to get correct direction of movement for yaw correction, was done in Mission Planner. Flew great on maiden flight only used stabilized and alt hold. I do have problems with GPS in Loiter, but I think the issue is with the APM 2.0. I have not flown in AUTO mode yet.
I will be make a scratch built Tricopter soon using the information at http://rcexplorer.se/ as a basis.
Richard, there are lots of reasons why one should pick one over the other, why don't you go for an airplane? Basically it depends on your tastes nowadays.
Steven, thank you for the advice, my kk2 board will soon arrive and i'll build my first tricopter using that, just to learn to fly, so it will be easier to fly the APM.
Peter, thanks for the offer, when i'll start running into trouble i'll think of contacting you.
I opened this discussion so that the other beginners that are thinking of building a tricopter with APM will find it easier, so i would like to talk here, not on private.
I don't have anything right now (well, i do, but i'm not planning to use it in the tricopter). I'd like to buid a new tricopter from ground up. This is why i'm asking you to recommend the parts.
What motors do you use and why? What kv do you preffer? Do you want high speed or high torque?
What ESC do you use? Do you go with BEC or UBEC, why?
As a beginner i'd go for the wooden frame too, as it's cheap, it's easy to make, it takes out some vibrations. What body for the frame do you recommend? Do you preffer the plyable arms? How safe are they inflight?
What servo do you use? Does it have to be really strong to turn the motor? How to choose one?
This is what i'd like to know, so when someone is thinking of buying parts for a new tricopter he'll know what to choose.
Thank you again for the reply! Oh, and sorry for the bad english :)
