I  put the code  at   https://github.com/diydrones/visual-followme   on a rasberrypi  which is connected to a APM ,and I start the mavproxy, do"module load droneapi.module.api",and typed "api start drone_script.py" ,and there is some error like below : " Exception in APIThread-0: No module named file_utils
Traceback (most recent call last):
  File "/usr/local/lib/python2.7/dist-packages/droneapi/module/api.py", line 325, in run
    self.fn()
  File "/usr/local/lib/python2.7/dist-packages/droneapi/module/api.py", line 605, in <lambda>
    APIThread(self, lambda: execfile(args1, g), args1)
  File "drone_script.py", line 8, in <module>
    from file_utils import Logger
ImportError: No module named file_utils"        I really can not find the reason.
  • I'm also having similar problems when loading modules... it only give me error when I try to use one of my modules...
    Did you solve it?
    • Yes,I solved it at last
      • how did you solve it?
        • The last problem faced is in the rasberrypi's command line I cannot start the frame flow, so I use the remote desktop of win7 to connect the rasp 's X window, and I use the command of Xwindow .and the frame captured by the camera pop up which indicated the red blob locked.  I do not know what is your problem.
          • My problem is that if I have a module with functions it can never find it... in normal python it does not give me problems... but when doing it with droneapi, i always get this error:
            STABILIZE> api start pix-goto.py
            STABILIZE> Exception in APIThread-1: cannot import name vc Traceback (most recent call last): File "/usr/local/lib/python2.7/site-packages/droneapi/module/api.py", line 321, in run self.fn() File "/usr/local/lib/python2.7/site-packages/droneapi/module/api.py", line 592, in APIThread(self, lambda: execfile(args[1], g), args[1]) File "pix-goto.py", line 18, in from modules.vehicle import vc
            ImportError: cannot import name vc
            STABILIZE>
            My module is named vehicle.py and its inside a folder named modules, with its __init__.py
            • Maybe you can join the room https://gitter.im/diydrones/dronekit-python  it is about dronkit-python
            • I have never seen pix-goto.py ,which package is it contains in, some mission like go to a specifed destination?
              At first, The problem  I faced is "@rmackay9 I put the code at https://github.com/diydrones/visual-followme on a rasberrypi which is connected to a APM ,and I start the mavproxy, do"module load droneapi.module.api",and typed api start drone_script.py ,and there is some error like below : " Exception in APIThread-0: No module named file_utils
              self.fn()
              And someone told me to do this :"
              you have to add the python scripts' path to the python execution path. A brutal way, is to insert these commands at the top of drone_script.py
              import sys
              import os
              sys.path.insert(1, os.getcwd())
  • somebody told me to add "import sys
    import os
    sys.path.insert(1, os.getcwd())"   on the top of the drone_script.py
    and then the tips turns to be like below:
    Exception in APIThread-0: astype() takes no keyword arguments
        self.fn()
      File "drone_script.py", line 11, in <module>
        from polyphemus import process_stream
      File "/home/visual-followme-master/visual-followme-master/src/polyphemus.py", line 6, in <module>
        from red_blob_detection import RedBlobDetector
      File "/home/visual-followme-master/visual-followme-master/src/red_blob_detection.py", line 6, in <module>
        class RedBlobDetector:
      File "/home/visual-followme-master/visual-followme-master/src/red_blob_detection.py", line 8, in RedBlobDetector
        hist = hist.astype(np.float32, copy=False)
    TypeError: astype() takes no keyword arguments
    • And now some tell me to update numpy,I tried,but no use
      • The reacent situation:
        STABILIZE> DroneScript - Visual-Follow Running
        libv4l2: error setting pixformat: Device or resource busy
        HIGHGUI ERROR: libv4l unable to ioctl S_FMT
        libv4l1: error setting pixformat: Device or resource busy
        HIGHGUI ERROR: libv4l unable to ioctl VIDIOCSPICT
        Exception in APIThread-28: No cameras found
            self.fn()
          File "drone_script.py", line 47, in <module>
            video_in = open_camera()
          File "drone_script.py", line 38, in open_camera
            raise Exception('No cameras found')
        Exception: No cameras found
