Tuning PID loop
hello all! Anybody knows how to set the correct values por the PDI control?
Is there some methods to tune it? or free soft? Im fed up to trail and error techniques...
Anyone found the way?
thanks!
    Franco, just to test as well, can you try disabling the airspeed sensor. (this is just t see if anything changes)
  • Thanks Michael.
    Hope Franco will have better results :D
    what gps do you have, it only apears to be putting out data at 1hz
  • Hi Franco, I'm struggling with the same thing, can't get my alt hold to work properly at all, what would be good is a guide for what to alter given certain reactions, and what you would expect to change if your multi is bigger/ heavier, hopefully someone can point us in the right direction
