Turnigy G-10 810kv for Octocopter
Please I need some advice anyone!
Im putting together an octocopter. Im going to be using the Turnigy G-10 810kv motors.
http://www.hobbyking.com/hobbyking/store/__19020__Turnigy_G10_Brushless_Outrunner_810kv_10_Glow_.html
According to the attached copter xcoptercalc, all will be fine.
I just want someone other than a calculator to tell me it should work.
I dont wanna buy 8 motors to find that it dont fly...
Help me Obi-Wan Kenobi, you're my only hope ;)
MK using turnigy g10-810.pdf
  • OIC you already did that!
    mauahahahaha
    Do you really need an OCTO? I started on a octo...it was overkill and hard to transport, build with what you want to lift inmind
    Checkout my hexa using 6 of the Turnigy SK3536 910kv 310w, I have a 3 axis gimble and retracts to mount shortly, with a 8ah 4s im 3.4kg
    The yellow ropes where on as I was doing PID tunig aka strap it inbetween 2 seats and tune (The best way to tune)
    3692306826?profile=original
  • Go here, and select the motor from the drop down menu, set up the rest as you would have it incl weight and WHAM the force will be with you!
    http://www.ecalc.ch/xcoptercalc_e.htm?ecalc
  • here are the motor specs:
    Spec.
    Battery: 2~4 Cell /7.4~14.8V
    RPM: 810kv
    Max current: 42A
    No load current: 11V/1.2A
    Internal resistance: 0.035 ohm
    Weight: 140g  (not including connectors)
    Diameter of shaft: 4mm
    Dimensions: 35x50mm
    Test Data:
    11.1v - 13X4 Prop - 21A - 1570g Thrust
    11.1v - 12X6 Prop - 26A - 1590g Thrust
    14.8v - 10X5 Prop - 25A - 1650g Thrust
