First time poster here, searched but didn't see anything immediately that addressed this.
I am running 2.5 and have basically removed a kk2 in a Quad.
The ESC's beep when plugged in.
All the movements from the Turnigy 9x Tx show up in the radio calibration page, I can even arm/disarm it.
But for some reason I cannot get the ESC's to respond or even move the motors? When I put the KK2 back in they work perfectly. The ESC's are HK 30a Blue and are still working, they beep through motors when plugged into the APM.
Any Ideas? I seem a bit lost  Thanks in advance
Cheers, Mark
  • Hi
    Maybe you should try this:
    1. First, Calibrate your ESCs all in one for min and max throttle. After calibation you should hear tone, indicating your battery cell.
    2. Connect your USB or telemetry, then calibrate radio, compass declination, accelerometer (release all the props for safety). Without this calibration, the quad won't armed
    3. Do compassmot with command line setup. This is a must if you want quad run in auto mode.
    4. Set another thing, like failsave, sonar, etc if needed
    Hope this help.
    Happy flying.
