I can't mount my sonar below the CoG on my hex a so I was going to mount it on an arm, but then I realized that when the craft banks to hover against the wind the sonar would show a change in height.So I was thinking if I put two of the same sonars on a Y cable and put one sonar on an arm and the other on another arm, would the two analog signal result in a the final output being the average of the two analog signal?Or would that result in the two analog signals adding together?Or would I need to connect the second to another analog input and modify code to average the signal?
