UART0/2
Somebody can confirm that I can use on APM2.5 UART0 and UART2 together , one for connecting a bluetooth serial device and the second to connect a serial sensor?
My objectiv is to control my octoquad by bluetooth and tranmit the value of my sensor (a humidity sensor) by bluetooth.
Sorry but I didn't find a clear answer on that point. I am developper and can modify the code if needed.
Thanks for support.
Cheers
  • I want to try something similiar. Have you results so far?
    • Finally my sensor used analogical Input and so I didn't need 2 serial lines.... But yes, you defintely can use UART0 and UART2 together...I tested it .. . knowing that one of them is used by the USB connector, you must unplug the usb for your test.
