Hi guys,
I use an xBee Explorer Regulated with an xBee Pro 802.15.4. The first one has an smd LED hooked up with the APM Tx wire, so I could verify if something is sent from the APM.
It was blinking even with the UART0/2 connection, but quite faintly. (Which is understandable, as there are a few 1k resistors in the MUX circuit). The xBee however did not pick up the signal, because I was not receiving anything on the remote side.
After spending several hours, I've finally hooked up the Tx signal directly from the UART0 outlet on the APM board, and surprise, immediately works, xBee now gets the signal properly. (The LED on the xBee Explorer is now blinking brighter, but once again, I don't believe that's something that could make the difference.)
Because all the xBee Explorer puts in between the Rx pin of xBee and Tx pin of APM is a single diode (5V -> 3.3V), I tend to think this is something the MUX circuit of the APM board messes up.
I'd be curios to check the shape of the signal coming out of UART2/0, but unfortunately I don't have an oscilloscope.
Board otherwise fully functional, APM version 2.5.1.
I can live without it, but we could debug it for the future generation :)
Cheers, Attila
    That XBee breakout board doesn't do proper level shifting. It works on the principal that a signal is 5V, not that 3.3V is compatible with with 5V devices. Get the XBee Pro or the newer https://www.sparkfun.com/products/11373 and it will work great. (Or this http://store.3drobotics.com/products/xtreambee-xbee-adapter-board )
    It's not an APM problem but the XBee adapter boards, lots of complaints in sparkfun comments for this same reason
    SparkFun XBee Explorer Regulated
    The SparkFun XBee Explorer Regulated takes care of the 3.3V regulation, signal conditioning, and basic activity indicators (Power, RSSI and DIN/DOUT…
  • I have exactly the same problem. Any news from the APM guys if it is a hardware/software problem that we could solve without sending back the boards?
