uBlox GPS to APM 2.5
2
Hi guys,
I finally received my quad-C kit yesterday and I am well into the process of assembling it. However, I ran into a problem when connecting the GPS receiver (uBlox). The GPS receiver came together with a short six-pin cable which I assume is for connecting it to the APM. The GPS receiver has a six pin connector which fits the cable nicely, but the connector on the APM is only five pins! Am I using the wrong cable, was I supplied with the wrong cable, or is there some trick I haven't seen yet?
Thanks,
kolaf
  • Hey there, whats the 6 pin header type called? I have the APM 2.5 but am lacking the correct cable. Currently have molex 4 pin both ends... no good :(
  • the GPS uses only 4 pins
  • It plugs in on the side, not the top ;-)
    Here's a picture (and a sneak peek of a GPS mount I made that I was going to blog about).
  • Never mind, I found the six pin connector on the APM. I was just trying the wrong hole :-(
