UBLOX problem with APM 2.0
Still having issues. I purchased a UBLOX LEA-6 from 3DR and when it came, could never get it to recognize any satellites. Did an RMA and they sent me a new unit. Getting the same result. In the meantime, I had received a JDrones Mediatek unit with battery - it works perfectly.
With the Mediatek, from a cold start, it took 5 minutes to get a lock and once locked, took under a minute each time it gets power cycled.  Usually getting HDOP of 1 and 10-12 satellites.
With the UBLOX, using same cable and APM2 in teh same location, it sat out for 2 hours ans still had no lock of any kind. Mission Planner shows 0 satellites and 100 HDOP.
Is it possible something is wrong with the APM2 that only shows up with teh UBLOX but not the Mediatek?
What do I need to do to connect the UBLOX to my PC to see if it is working properly?
  • Hey Chris! No - no blue LED. The Mediatek comes on as expected - flashing blue then locks. On the UBLOX, just the red LED is on. Using the same cable that came with the UBLOX on both units.
    Is the blue LED coming on solid on the uBlox?
