I am new to Android SDK, and I am trying to install and run the Andropilot into my Android device. I built the code and ran in a Nexus 4. The application installs, however, when I start the Andropilot, it crashes and shows the message "Unfortunately, Andropilot has stopped".
Can somebody help me out?
Thank you.
Sure - what Android device are you using and what is the version of android on that device? Can you tell me the time in UTC when the crash occured (so I can check for crash reports at google).
Also, what is the version of andropilot you are using (you can get that from settings / apps / andropilot).
My devices are Nexus 4 and also Nexus 7. Nexus 4 is running on Android 4.4.4.
I am using Eclipse to debug and run the application. Actually, I think I am skipping some step. I am running the app as it was a normal android application. I mean, sbt is already installed on my computer, but I am not using it to build the project. As no erros are found by Eclipse, I thought I was done.
Ah - I see! You built it yourself. Cool beans. I don't think it is possible for just eclipse to build it correctly. Can you try building it using the steps in the README and let me know what you find?
Ok, I will try that. Thank you very much for the help :)
