simply use APM Planner to upload new firmeware, then use the Setup button after. this will put all defalt PID's; so if you have customized your PIDs youll need to re-do those.
Also once you do the Setup, youll need to go into CLI mode, setup, modes; to change your mode switch to what you want.
