Upgrading battery noobie question.
I have these motors on my quad:
https://hobbyking.com/en_us/multistar-350-to-450-frame-size-2212-combo-set-with-self-tightening-propellers-cw-ccw-set-of-2.html
with DJI 9443 props.
My quad has to sit on 70% throttle to stay in the air and when the battery gets low it needs almost 80% throttle. I can and will shed weight from its heavy frame (roughly 550 size).
I currently use a 3 cell battery, but will a 4 cell battery be OK for these motors? They say a max amps of 20A per motor and I hardly use more than 9 amps at full throttle with my 3 cell battery.
I have seen very similar motors (like the DJI E300) seen used with 4 cell batteries.
But I am new to this and want to make sure with someone who has experience with this.
Even if you think its worth a try or not, let me know. If it is worth a try what can I do to make sure it is safe for my config?
Thank you.
  • Hobbyking had a special on a battery that would fit my config. I bought it, going to give it a try. I will post my results. After looking around more I may have to limit the throttle to not overheat the motors. My quad will weigh almost 2 kg, so definitely on the heavy side for my motors! Regardless of weather or not it works, an extra battery wont go a stray. :)
