As drone platforms become more capable, power-system compatibility is becoming an increasingly important part of aircraft integration. For operators and builders working with the EFT X950, the platform now supports the EB1219 smart battery, providing another option for powering and managing the aircraft.
If your X950 is currently using an XT90 battery connection, the upgrade to the 12-pin blade connector can be completed through a straightforward modification process.
The upgrade starts by opening the flight controller compartment to access the internal connection area. After removing the existing components, the original battery connection can be disconnected and replaced with the corresponding connector designed for the EB1219 smart battery.
The video demonstrates the process step by step, including opening the compartment, accessing the connector, removing the existing connection, installing the new interface, and routing the related wiring. Once the modification is completed correctly, the X950 can accommodate the smart battery connection and be prepared for operation with the EB1219.
This type of upgrade is particularly relevant for users building an industrial drone platform around specific mission requirements. A modular power interface gives integrators more flexibility when configuring an aircraft for different payloads, operating environments, and applications.
For operators developing a cargo drone, the power system is closely connected to overall aircraft configuration and payload planning. A flexible platform can also be useful when developing a CARRIER DRONE for transporting equipment or supplies, or a delivery drone intended for repeated point-to-point transportation.
The same principle applies to a drone for delivery: the aircraft needs to be configured around the required payload, battery system, flight-control architecture, and operating conditions rather than treating the airframe as an isolated component.
The X950 is therefore more than just a drone frame. It can serve as a configurable platform for developers, integrators, universities, and industrial UAV teams that need to adapt the aircraft to different onboard systems.
If you are already operating an X950 with an XT90 setup and are considering the EB1219 smart battery, this modification guide provides a practical reference for understanding the required connector and wiring changes.
Before performing any modification, make sure the aircraft is powered off and follow the applicable EFT installation instructions and electrical-safety procedures.
For industrial UAV development, small hardware changes such as battery connectors can make a significant difference to how easily a platform can be integrated into a complete system.
Have you upgraded your X950 to a smart battery system? What type of application are you developing — cargo transportation, inspection, delivery, or another industrial UAV mission? Contact us to share your idea.
