  • Fixed it - turns out it was related to another issue I was having, http://diydrones.com/forum/topics/upload-succeeded-but-verify-faile...
    The problem was I had a 4G USB dongle connected to my laptop with an a powered extension cable, i'm guessing it must have been causing issues on the USB ports because as soon as i disconnected that i was able to connect fine and also I had no dramas updating the firmware on the 3dr radio.
  • Tried it with a 5V TTL logic levels and i still get the same result.
    Does anyone know of a way to get it out of bootloader mode so I can at least use it with the old firmware or is it completely bricked now?
  • Just realised i have a 3.3v ttl ftdi cable, what are the logic levels of the 3dr radio?
  • I can't even see the settings it's configured for as when i press Load settings it comes back with "failed to enter command mode".
    Maybe i have a dodgy radio?
