I'm having problems getting the arducopter 2.0.38 software working through the arduino IDE. I'm tring to fix some camera issues (wrong direction and scaling) and this requires recompiling the code.
I used information from http://code.google.com/p/ardupilot-mega/wiki/Code . I downloaded Arducopter2.0.38.zip and moved ArduCopterMega an libraries in a new directory.
After that I could open ArduCopterMega.pde and according to the IDE it compiles fine.
When I upload it to the board, the orange LED's  blink, stop blinking and after at some time the IDE says 'Upload done' without any errors.
However when I fire up the board, nothing happens, no blinking lights, no CLI,  nothing... this is true for both WIndows and lkinux arduino.
When I upload the standard software through the Mission planner everything works fine. But I normally use linux and the Mission Planner doesn't work very well in anything other hen Windows.
  • Did you ever get this resolved? I'm having the same issue.
    Did you restart Arduino? That is needed when changing Libraries.
    also you can try to upload the most basic sketch:
    void setup(){
        Serial.begin(115200);
        delay(500);
        Serial.print("Hello World");
    void loop(){}
