Hi Guys,
I got my new APM 2.5. I am running it under Windows, arduino 1.01 with VS 2010. I am using ArduPlane 2.68 and 2.67 source code. It builds successfully. However, the problem is:
1) When I open the serial monitor the accelerometers/ gyro keep calibrating infinitely. Says Initializing APM.....Initializing APM.....?? Initializing APM.....
2) In the beginning it does BLOCKERASE 390: BL ERASE.. Any issues with dataflash card?
This does not happen when I load it using Mission planner and test in CLI mode (it does not do the init_ardupilot() setup, I believe). I haven't changed a bit of code yet.
Why does this happen? Has it happened with anyone else? See attached output file I got from Serial monitor.
Thanks for your help!
