URGENT!! Project with ARDUIMU V3!
Hi everybody,
I'm a newby working with Arduimu v3 and I'm working in a project that only needs the ROLL data from ARDUIMU v3 and then I use the ROLL angle data to send it to a servo.
The problem is that when the ARDUIMU v3 is completly horizontal I get ROLL 0 degrees, this is OK.
However when I shake slightly the board but always horizontally I get ROLL values different than 0. I can understand a variation near 0 but when I push or shake the board horizontally I get 45º 30º 70º..... depending on the movement.
I'm just trying to upload code releases but the problem is the same. Sincerely I tried to load the last release of ARDUIMU 1.9.8 but I can't do it becaus an error appears.  :-((((
Can anyone help me!!! I'm pretty sure this bug is already solved by all of you that you are experts!!!
Can anyone sen me a valid firmware??? I'm using Arduino 0.23 (.pde files)
My email is: rubentxo(at)msn.com
PLEASE! It's very important
Thanks!
