Usage of drones as Lora-Repeater/relais
I'm not only a drone and WWI-biplanes-guy, I also like to start high-altitude balloons.
As I'm living in Switzerland, we have a quite challengimng topography here.
My idea is to put a Lora-Repeater attached to the landing gear of my Typhoon H, start the drone and lift here up to the maximum height (120m above ground).
There I see a quite good chance to pick up a ora-signal from the ground (=means the landed Payload of the balloon) and re-send it to my Lora-Gateway or chasing-computer.
As I'm not so experienced in programming, I try to find a ready-to-use-solution for this lora-repeater functionality.
Is there any experience around or even an already tested code-solution around ?
Thanks in advance for any hints.
