Hello,
I have purchased a separate BEC to provide the 5V supply for the processor board and the Radio receiver, rather than use one of the four that come with the motor control ESCs. The reason for this is the uncertainty that still seems to surround the random blowing up of mux ports, which seems to be related to possible misbehaviour of these BECs when connecting and disonnecting USB power when a LIPO is connected.
Please can you advise me whether I have the changes correct here:
1. dont connect the 5V wire from any of the ESCs
2. Connect the inputs of the separate BEC to the LIPO supply somewhere convenient on the power distribution board.
3.Connect the 5V output of the separate BEC to the 5V rail of the right-angled radio receiver connectors
Should I put a shottky diode in series with the 5V BEC output so that the USB supply isn't trying to drive the BEC when the LIPO is disconnected?
Thanks for your help. Awesome project guys.
Rob
i think that the newer version of APM is protecting USB and preventing it to feed the RC rails.
the proof is that my receiver is connected to the APM rail, but when plugging the USB, it won't power the receiver.
Sure you can use external BEC's. We are using external BEC's on all our ArduCopters. If you don't use any Power Distribution PCB, easiest way to separate BEC powers coming form ESC's is just by cutting center wire (usually white) and then just hook up your BEC to APM RC rails.
If you do use ArduCopter PDB, then just leave out that power connection (red/black) cable and use output cable from your BEC
