I have tried to set up multiple Ail Servos as outlined in the Wiki. I wanted differential as well. The problem is that both servos only work in the "manual" mode. Obviously, they need to work in all modes, with the exception that in autonomous mode, RTL for example, there will be no differential. I must be missing some simple point. Any help appreciated.
Best,
Steven
Oops. Forgot to re-run the Radio Calc after setting everything up. So Ch 6 was centered and not going anywhere. After running Radio Calc., all is performing as expected.
Steven
