Hi.
I am designing a X8 copter using 6s power source. Im using the apm 2.5 for control and wanted to be able to use the power module to measure current and voltage.
However it is listed to support only 4s.
I was hoping someone has had this problem before and has found a solution to it.
Is there a possibility of measuring only 1 cell (using the small lead of the battery), instead of all 6? Similar as was done with APM1.
If i do use the power module with 6s, will it blow a fuze or simply not work?  Will I still be able to measure the current?
  • Bump.
    I would really love to hear from someone who knows more about this.
