I just got the High Resolution PCTx and the Saitek X52 Joystick to use with my Spektrum DX8. Everything was going fine, I downloaded the ServoCommander software, and when I hooked my PCTx in the green box came on and said HR PCTx connected. When I go to >edit then >input devices, I can see that when I move the joystick around it reads it on the screen, I can see the values jump around as I swivel the Joystick. I set my DX8 trainer mode to Programmable Master, so that the DX8 is the master and PCTx is the slave so when I push the trainer button down the PCTx should take control. The problem is when I press >Start on the ServoCommander nothing happens, when I look on the APM Mission Planner Screen under Radio Configuration, none of the commands from the Joystick are being relayed to the board, when I release the Trainer button it recognizes the inputs from my DX8. So bottom line is my PCTx is communicating with my DX8? Does anyone have any ideas, I thought the DX8 works with PCTx, I bought this radio to specifically work with the PCTx.
Can anyone give me some advice as to how to get this working. I hope some other people got the PCTx to work with a DX8.
Thanks,
Hi Seth,
I would contact Phillip at Endurance RC and see what he has planned for updating the Servo Commander software. The other issue that you might want to consider is: Did you put the DX8 in the 11ms mode of operation? Normal operation is the 22ms mode.
TCII
Seth,I've just seen on the Endurance RC site this warning shown below the PCTx :
Sorry to be the bearer of bad news.
Mike P.
