Using XStream™ OEM RF Module - Help Needed..
I have a MaxStream wireless modules and they have serial ports.
I would like to use MaxStream wireless modules instead of the Xbee wireless modules
Below are serial port pins info :
DB-9 Pin RS-232 Name Description
1 DCD Data-Carrier-Detect
2 RXD Received Data
3 TXD Transmitted Data
4 DTR Data-Terminal-Ready
5 GND Ground Signal
6 DSR Data-Set-Ready
7 RTS Request-to-Send
8 CTS Clear-to-Send
9 DI Ring Indicator
To which pins on the serial port do I connect the four header pins in the IMU shield's "Telecom" port.
Thanks,
Tim.
  • There must be some way to connect them.
    This won't work. APM, like all RC electronics, can only use 5v TTL-level serial. Ie, not DB-9 RS-232.
