I want to land a plane nose-first by spinning a propeller backwards to lessen its vertical acceleration. The propeller may need to be coaxial so as to minimize angular momentum. Perhaps an airbag or such low tech-fixes as a mat on the grand or a padded nose would be needed to make this landing feasible.Coupled some sort of DGPS station at the point of landing, I feel that this could greatly decrease the area required for landing. Has it ever been tried?
Sound interesting.... but how will you conrol the pitching effect of external forces such as wind? If the aircraft is in a vetical position the wings and horizontal stabilizer will have a huge sail effect. There won't be any slipstream over the tail surfaces for control if the propeller is spinning backwards... actually the prop "may" be dragging a small amount over them in the reverse direction!
I say good luck to you. Good to see different ideas but that looks like a tough one to me.
Landing nose first is not easy as a technical venture but you have the right ideas so far. Reverse thrust has been done by Bill from UDB.
A slow vertical landing is usually by parachute like Krzysztof's Pteryx. A fast vertical landing is called a crash.
