Video goggle's (FAT SHARK) With Head Tracking
(Futaba data cable accessory required)
Note: With optional Futaba data cable, the head tracker can work with
higher end Futaba radios that support selective student channel mixing.
- Connect Data cable and turn on radio.
- Enter TRAINER menu and assign desired head tracking channels
to FUNC (must be set on FUNC). Default is CH 5//6.
- Individual servo direction can be set in REVERSE menu (reverse
not available for 7C users, must reverse direction in HT menu).
- Servo center point can be adjusted in Futaba servo off set menu
(or use HT menu #7 to set servo center offset).
When connecting via the Futaba cable, the headset battery pack is not
needed as the radio will supply power to the headset through the cable.
 "I can not get any of these things listed above to work" Trainer is on and no luck-also it says TX will power the goggles but "NO", was thinking it was my radio but plug it into my pc and trainer plug is working properly. EEERRRRRGGGG!! I am getting very frustrated after 3 days of no help from HK or Fat shark??
3690926349?profile=original
  • Hi Douglas,
    I was wondering if you got it working cause I have a 6ex and would like to buy the new FatShark Attitude SD Witch I assume work the same that the Dominator HT.
    In your post you talk about the TX powering the goggles, but I think you should try to power the googles normally (with your Lipo).
    In my searches for a person who got FatShark HeadTrakers working with a Futaba 6ex I found this from HK : http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=11848
    Don't know if it could help....
    Bye
May 21
Azjeg liked Azjeg's profile
Apr 27
Benewake LiDAR liked Benewake LiDAR's profile
Apr 12
Gremsy liked Gremsy's profile
Mar 12
