Virtual BreadBoard Simulation software
Hi guys, I'm probably the first one too late on this one, but I stumbled upon this free sim software for the Arduino platform, along with others.
I thought someone might need/like this, I found it to be a great help as Arduino is completely new to me. I was playing with this till the wee hours of the morning.
Hopefully it is of use to some of you, and this isn't a redundant post..
You can find it here: http://www.virtualbreadboard.net/
VirtualBreadboard is a simulation and development environment for embedded applications that use microcontrollers. It is easy to use and can replace a protoboard for experimenting with new designs. VBB simulates many of the PIC16 and PIC18 microcontroller devices including peripherals and supports a wide variety of simulated components such as LCD’s, Servos, logic and other IO devices that can be used to model and simulate high level circuits.
VBB Standard Version
The VBB Standard version is freely available and showcases many useful applications and tools
  • TekTiles - TekTiles are drag and drop hardware objects which can be plugged together to rapidly create new electronic circuit designs.
  • FlowCode -Visual programming of TekTile hardware applications
  • Muvium Metal - Tight integration with the Muvium Metal ahead-of-time java compiler including source code editor, project management, simulation support and in-circuit debugging and programming using the ICD2/ICD3 programmers.
  • Arduino - Support for the arduino microcontroller with many examples
