Finally got around to wiring my AttoPilot 90A/50V sensor. I was just testing it without any load and could get the voltage about spot on but the current, instead of being zero, is about 130A!!!. Would anyone be able to advise what I need to do differently? Also, I set to the appropriate AttoPilot 90A/50V and when I save it reverts to other??!?!
Thanks a lot,
Steven
Are you sure that the voltage and current wire is in the correct pins of the sensor and the APM? could you have crossed the wires.
