Hi All,
Just a quick heads-up for those of you flying with an onboard camera and using GPS. I use a gopro with no problems, it doesn't seem to interfere with anything.
However today I decided to try a different cam
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=17200
I did a quick auto flight without the camera, everything went beautifully well, so i decided to do an onboard video for your viewing pleasure.
I turned the camera on, tried a loiter and it just wandered. I checked the mission planner - NO GPS FIX!?!?!?
What? I've just done an autoflight perfectly.
Thankfully before i stripped it all down my helpful friend pointed out that the only thing that i had changed was the camera - so i took it off and hey presto - a instant full 3D fix. This must be one hell of a noisy camera!
Watch this!
Have the same cam.
Yes I crashed with it onbaord...Most likely motor fail...but my GPS lock was 10 sats all the way through.
So no issues there.
Cam was about 10cm from the GPS module.
Its Ublox.
Maybe only the mediatek is affected.
Same problem....I have a HK wing cam on the front of my quad running NAZA...I had great GPS lock....even did a great compass calibration.....then i noticed I had bad sat lock everytime I took off.....I noticed ( and by chance noticed)...that when I turned my wing cam on...I would lose sat locks....even did a calibration with the wing cam on...to see if that would callobrate in....NOPE.....took that cam off for sure...also at one point before I noticed the problem...I went out of controll for like two or three seconds and I switched from gps atti to just atti....and landed fine
Hello mate! The same problem! My last flight could finish very sadly. The plan wanted to fly away. Just quick return to manual mode saved it.
Did you try to wrap a bit of tin foil around the camera and then check it?
Hi!
I was using the 720p HK Wing camera extensively with GPS for quite some time now and I did not see any problem.
I am using Venus638FLPx GPS and the camera was as close as 15cm from the unit.
It could be possible that your GPS is sensitive to some other frequency than L1.
Would have to run the camera on spectrum analyzer if needed.
