Hello Everyone,
I've recently run into a bit of a problem trying to write and read waypoints, with wireless telemetry, using the latest codes for ArduPlane and Mission Planner.  I can connect fine using wireless telemetry and everything seems to be working under the Flight Data tab, but whenever I try to read or write mission waypoints, I get the following error messages:
3690934986?profile=originalor
3690935034?profile=originalReading and writing via USB works fine though.
Any ideas anyone?
  • I'm having this same error. Anyone remebers solution?
    • In my case I had to double airspeed. Apparently there was timeout problems. My duty cycle is 10 %, so it slows down communication enough to timeouts occur.
    can you click on the link info, and see if many packets are being dropped?
    and also try changing the telemetry rates down in
    config>planner> rates
