Weird behavior in loiter/poshold
I have a weird behavior in loiter/poshold.
When i'm loiter and I want to yaw my copter, it's drifting backwards for about 3-4 meters and than will slowly go back to it's position where it started from.
Doesn't matter if I yaw right or left. It always "pulls back" a few meters and returns to "0" position.
In the pics I took from the log you can see that the Y is acting good, but the X looks like it's mirroring.
Can someone point me out the right way.
Thanks in advance.
FC is a Mini APM 3.1 running arducopter 3.2.1
  • Without knowing what exactly caused my problem, I found the "solution".
    Started right from the beginning.
    Flashed the APM mini and calibrated and (auto)tuned everything all over again.
    Flies fine now...........
  • nobody any idea???
  • EDIT:
    By "mirroring" I mean that the NTUN.DPosX is the opposite of the NTUN.DVelX value.
    I've (re)calibrated the external compass and autotuned the copter. GPS had 9 sats.
